Deletes aliases for ExtremeXOS commands.
| alias_name | Specifies the alias name to be deleted. |
| -a | Deletes all aliases. |
N/A
To see a list of your current aliases, use the command alias with no arguments.
When using this command, you can auto-complete an alias name by typing part of the name, and then pressing [Tab].
The following example deletes all aliases:
unalias -a
This command was first available in ExtremeXOS 22.3.
